Enables use of the switch's USB port.
| usb | Specifies USB port on switch. |
Enabled by default.
This command requires a reboot to take effect. This setting persists after reboots. To remove it, use the command disable switch usb or use the command unconfigure switch {all | erase [all | nvram]} with the all option.
Stack support is not available. You need to run this command individually on each node in a stack.
The following example enables use of the USB port:
enable switch usb This setting will take effect at the next system reboot.
This command was first available in ExtremeXOS 22.3.
